Hello all,
Bit of an issue if someone is able to offer some advice please.
I've just finished a refresh / upgrade of my system, the new(ish) compotents are:
Asus X99-E WS motherboard.
GTX 1080 graphics cards (I actually have 3 of them, but for troubleshooting purposes I'm only going with 1 for the time being).
Corsair Dominator Platinum DDR4 (32gb) brand new.
i7 6950X.
Old components (mobo inc CPU and memory, and GFX) were removed, new stuff added in, etc etc. HDD re-connected, powersuplly connected (the only part the old PSU - an AX1200w Corsair unit - couldn't provide was the 6pin 12v connection in the middle of the mobo - which upon Googling wasn't deemed a requirement unless the CPU is heavily overclocked - might need to check this??)
The PC is watercooled - part of the refresh included new pumps, flush through, new fluid etc.
Once finished, confirmed the WC is working as expected, HDD plugged back in, machine booted to BIOS, with a message to disable the CPU fan.
Bypassed this message, booted to Windows. All good (needed a re-install the OS, but that was all part of the plan).
Rebooted, went into the BIOS, disabled the CPU fan warning, went to exit the BIOS and (annoyingly and mistakenly) some odd update, percentage bar decided to do it's thing... no idea what this was, I'd stupidly taken my eyes off the screen. I let it finish, but it has failed to boot into the BIOS since.
Note: at no point have I connected to my LAN or enabled any internet connectivity.
I'm extremely confused. I've removed memory, HDD, GFX. I've tried different GFX cards. I've tried hitting the onboard clear CMOS button. Nothing I've tried is allowing a screen to load (BIOS, anything).
Also, more annoyingly, the Asus X99-E WS has the Q-Code display on the board, however mine is perma-stuck on 0.0 (disabled). And I can't find a way to get this to help display someting useful.
Any ideas how to really, properly, clear the CMOS on an Asus X99-E? Any idea how to get the Q-code function up and running?
If anyone has any experience to help troubleshoot I'd be grateful, as I've been at this all day and am now quite fed up lol.
And bloody Liverpool FC just got spanked.
Thanks.
i7 6950X.
Thanks.
