Having a small problem with my Revolt X 1200. When the ITX system is running, and I press the ATX system power button, the PSU terminates power completely. This only occurs in this order, not in reverse where the ATX system is running and I power up the ITX system. It also does not happen every time.
The system is totally dead and power cannot be restored for a short period of time, but it isn't a fuse as later it all powers up fine.
I am using the dual system capabilities, but with the 1200W PSU, don't think the specification is anywhere close to pushing the power limits:
ATX spec:
AMD 5800X
MSI X570 Tomahawk
32GB RAM
Gigabyte 3080 (2x 8pin model)
2x m.2 & 2x SATA SSDs
Full loop with D5 & 14 PWM fans off an Aquaero 6
ITX spec:
AMD 4750G
Asrock B450 ITX
32GB RAM
1x SATA SSD
I haven't been using the main ATX system as much as I would like but haven't encountered any stability issues so far (touch wood). Reluctant to take apart for proper troubleshooting given time and the loop so wondering if anyone has any thoughts/suggestions?
Cheers
Ian
ATX spec:
AMD 5800X
MSI X570 Tomahawk
32GB RAM
ITX spec:
AMD 4750G
Asrock B450 ITX
32GB RAM
1x SATA SSD
Cheers
Ian
