I didn't think about a moat tbh.. I'm just struggling now building a roof. I have the slanted bits done but stuck on corners, and I need middle posts for support as well. I didn't plan this far.
I used the pickaxeNice! Did you dig the moat with a hoe?
I have 2 floors. I will grab a picture of the roof on the 2nd floor laterOh ok that last picture makes more sense than my current house. I'll have to look up building tutorials, it's the roof part I'm stuck on.
Honestly it's a joy to look at too. Gives me strong BOTW feels!
Im kinda baffled that you can't play this game at Ultra settings in 4k on 3080 @ 60 FPS ! lol Ok the lighting is cool but everything else.....
Erm, there's no Ultra settings. I'm playing it perfectly fine with my rig all maxed. The game drops frames for a split second every time it auto saves, but other than that, silk. 90fps+ easy. I'm pretty sure a 3080 should run 4k at over 60 fps all maxed no problem.Im kinda baffled that you can't play this game at Ultra settings in 4k on 3080 @ 60 FPS ! lol Ok the lighting is cool but everything else.....
2nd floor picI have 2 floors. I will grab a picture of the roof on the 2nd floor later
Maybe a old ish laptop?What is the smallest x86 or x64 system we could possibly make that would run a dedicated server well enough? I’ve been looking at pico itx systems but there aren’t really any available. Has anyone tried the pi 4? How did it go? (Yes it’s ARM)
There is mild violence, gore and horror but I would say 13+ is safe with this.
Yep, so I re-purchased after my group (including LeMson) sorted out our MP
what problem are you having?Hi - do you know what caused the MP issues? I am having similar issues with a friend playing on my server and am reaaaaally desperate to find a solution...
Was it by any chance related to the steam discussion link you provided? Cheers!
I’ll ask my mate. It was certainly him not getting data on his end, which the link refers to - I think F2 ingame pulls up some net data where you can see this? I never did ask how he sorted it out but I’ll get back to you.Hi - do you know what caused the MP issues? I am having similar issues with a friend playing on my server and am reaaaaally desperate to find a solution...
Thanks in advanceI’ll ask my mate. It was certainly him not getting data on his end, which the link refers to - I think F2 ingame pulls up some net data where you can see this? I never did ask how he sorted it out but I’ll get back to you.
It was some ASUS software called GameFirst? He uninstalled it and everything was fine after that.Thanks in advance![]()
