- 19 Dec 2017
Thanks.
Scoreboard updated.![]()
Thank you, it’s very good of you to keep it update for all of us
Thanks.
Score: 16417
Graphics: 20231
CPU: 7938
i7-9700K @stock
Nitro + 6800XT SE
2600/2725 frequency, 1150 voltage, fast timings, 2100 VRAM, +15 power
Driver: 21.1.1
https://www.3dmark.com/spy/17827111
Direct from 3DMark a while ago.good score did you use the timespy bought with steam or separate stand alone version?
I keep getting 19830 on graphics score with my nitro 6800xt.
Silicon lottery I guess. My 5700XT was never able to get to the heights of some other scores no matter what I tried. Still performed well, just not exceptionally.On my 6800 XT Nitro OC just tried your settings. Timespy crashes for some reason, when it doesn’t I get 19600-19800 scores. Not sure why.
I have a 750w aerocool bronze psu- maybe that’s why?
cheers been a few years since posting a scoreScoreboard updated.![]()
Hi,
I managed to get my best timespy result so far here:
https://www.3dmark.com/3dm/58220775
3090 2145 / ???? Not sure what the second figure represents sorry?
3700x @ 4.11Ghz
461.40 Drivers
Graphics Score 21023
CPU Score 9815
It's memory speeds. Yours shows 1224 MHz. Need to multiply it to same level as others so in your case it would be 4896mhz.
