Hi mines not charging with the link cable while playing, any ideas? will it just go flat. only using it tethered with my old oculus account.
I think mine slowly loses power when tethered, but I've never played long enough to actually run out of power whilst tethered. I think it also doesn't start actively charging until it gets discharged a bit.
Right ok thanks, should be ok then hopefully. As long as I don't have to pay for the £80 cable lol.
Best place for prescription lens inserts?
I've predominantly bought VR to help correct left-eye dominance but doesn't help much that the screen isn't perfectly clear![]()
VR optician ?
they go to like -15, all other shops only do -9 i think
Oh, wait, you don't have the official link cable? Then it might not be charging as you play. Some of the USB cables are good enough to play on but don't charge while playing. When you bought the cable did you check to see if that was the case?
Thanks, just went to order and noticed my optician hasn't included my PD on my prescription!![]()
No thought it would be obvious thing.....I bought the Oculus Link Cable 3m, dethinton Usb to Usb C Cable. Getting 2.2gb transfer.
The worst game for VR nausea has to be the ISS game!
Thanks for the heads up about this game, added to my steam library, love zombie games.so i started playing that free Zombie game on steam, i probably could have played it more than 2 mins, but i was getting really tense i decided i best not ! lol
"Propagation" its called
