What about "picture framing"? I understand that Indian sandstone is very absorbent, how about mixing in some SBR with the mortar?
Also what are your thoughts on patio sealers for sandstone? I was going just leave it to weather naturally but every manufacturer appears to offer a patio sealer.
Thinking we had a burst pipe isolated all water, then went to investigate the boiler. Discovered that the washing machine had been pumping water up the boiler condensate drain line as the outdoor pipe had frozen solid, i've taken the boiler apart and looks like we need a new fan as ours has had about 5ltrs through it.
What an epic design fail, not unusual to plumb things this way apparently, been a fun evening!
I'm Tring to work out how it's plumbed, I thought condensing boilers had a small diameter pipe that should be angled so it doesn't freeze, whereas my washer goes into the sink waste.That is a bit daft, so without the boiler being affected the washing machine would have flooded the kitchen anyway?
What do you plan to do to prevent it happening again?
Is this waste pipe the type that falls in to a gully pot with a grate outside?
Mostly washing machines waste is plumbed into the waste under the sink. Usually its just a hose clamped to a nozzle.
Yep the washing machine would have flooded the utility room, water from the sink etc discharges through another pipe, this washing machine discharge is into a grey water open grate.
The reason for the above is because the downstairs toilet and both the sink and utility room sink flow into a macerator before going outside, due to the height and lack of a trap it would not be a good idea to plumb the washing machine into this.
Condensate drain from the boiler runs internally into the house (hidden), then it goes into a shared washing machine drain pipe to the outside.
Above will work 99% of the time because the boiler is much higher than the washing machine and the discharge outlet is not blocked.
However as we have found out when the outlet freezes and the washing machine is on, then we get the backflow situation.
Going to replumb the outside pipe so it cannot sit below grade in a pool of frozen water.
If you can, I’d also separate them so they are not coming out of the same pipe, makes any back flow impossible then.
That higher on the rhsPut up a curtain pole in the spare room / Mrs' WFH space
Before
After
That higher on the rhs?
I THINK it's the angle of the photo...lol.
No such thing, just turn it roundLol, yes it is! Or my spirit level is broken![]()
Might be the windows not straight, my experience of builders in that they struggle to make anything squareLol, yes it is! Or my spirit level is broken![]()
No such thing, just turn it round![]()
