how does longevity factor in when you can't buy one ?
You can't only if you find excuses.
just had a look at the bundle deal
you can still get 3900 + B550 Stric F for £535 which i consider a decent deal for the now.
or 3900 + B550 Tuf gaming for £510
or 3900 + B450 Tomahawk for £430
that is inside you budget and gives your 12c/24t of goodness for your encoding and scubbing.
I can’t tell you as I will get banned. But just need to search the above bundle in WWW you will find it.Where?
From the puget and TPU benches I saw, Adobe stuff doesn't seem to scale that well, the difference between the 10700K v 10900K or 5800X v 5900X is often rather marginal. But, other stuff like encoding, yeah, it seems to scale good.When it comes to video editing and encoding. The more cores the better. .
What's with the nonsensical posts? He clearly stated his budget was £350ish so you recommend a CPU for ~£600! (added to the fact that you'd struggle to pick one up makes it even more daft.)Hi,
There is only one choice - the 12-core Ryzen 9 5900X
▷ AMD Ryzen 9 5900X Twelve Core 4.8GHz (Socket … | OcUK (overclockers.co.uk)
+1 on that.... oddly the Ryzen beats it in Passmark though? AMD optimized?Of the two you mentioned definitely get the 10700k over the 3700x
Stop making stuff up that you don't or can't know about - you have no idea what he will be doing in 2 years or even if he will get a 5600X!The OP needs to rethink his budget if he doesn't want to come back in 2 years complaining about crappy performance from his new 6-core Ryzen 5 5600X, for example. If he buys that, though
The first post didn't include a specified budget
@smr
I do a lot of Photoshop and video work and it's a shame you didn't pick up the 5800X when OcUK were selling it for £380 as that is great in Photoshop and good for video work, though if a lot of your work is in Premiere Pro then that will favour going Intel (when results are close) as you will get the very real benefits of Quick Sync. Being able to use Thunderbolt also favoured Intel but you can also now get a B550 with Thunderbolt so that can now be discounted.
In truth, compared to what you have any modern CPU over the last couple generations will be a cosmic improvement. Of the two you mentioned most definitely get the 10700k over the 3700x.
If you had a decent GPU my recommendation might have gone with the 3900X as those extra cores can give a nice boost in Premiere Pro plus you would have the benefit of the v14.5 Prem Pro including both GPU-accelerated encoding and decoding which would help offset the Intel Quick Sync advantage.
When GPU prices normalise you should probably look to investing in a decent midrange one as there are good benefits to be had in both Photoshop and Premier Pro when you can enable GPU acceleration.
Thanks for the advice. Yes I saw the 5800X for around £380 a week or so ago, thought / knew that was a good price but tbh, after the AMD launch I have been busy and hadn't had time to read up on what to buy hence the reluctance to buy it then, even though I know it would go back up in price.
The only slight worry about the 5800X is these high temperatures some people seem to be having, but there again I'd be looking to add liquid cooling as I have now, I just prefer to cool the CPU that way instead of air. Hopefully they might be that price again soon.
It sounds like AM4 is being supported for a while and there's the option to go straight in with a PCI 4.0 setup right now with AMD, buy an AMD CPU and plug and play with the AM4 / PCI 4 compatibility.
That said I'm not sure whether pci 4 is even that important at the moment and for the foreseeable. I think it would probably make most sense to go for at least 8 cores and 16 threads...
For a budget of around £350ish from what I can see there are at least the following cpus within budget or close to it, in no particular order;
1) Wait for the 5800X to come back to £380 (if it ever will)
2) Buy an i7 10700K CPU 8C/16T 3.8Ghz for around £315
3) Buy an AMD 3800X for £320
4) Buy a 3700X 8C/16T (as I'd most likely see 0 performance difference between this and the 3800X) for £290
5) Buy an i9 10850K 10th gen for £380
Which platform and CPU to go for....
First of all, I'm sure I don't need to tell you but ignore @4K8KW10 as his post is idiotic in the context of your requirements.1) Wait for the 5800X to come back to £380 (if it ever will)
Only problem is its way over the ops budget and hard to get hold of the 10850k is in reach of ops budget and is readibly available so why the 5900x is a faster cpu its totally irrelevant in this instanceRyzen 9 5900X is up to 70% faster than the crappy Core i9-10850K:
https://www.cpubenchmark.net/cpu.php?cpu=AMD+Ryzen+9+5900X&id=3870
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i9-10850K+@+3.60GHz&id=3824
The only thing crappy in this thread is your advice.Ryzen 9 5900X is up to 70% faster than the crappy Core i9-10850K:
Of the CPU's you listed then the 10850K is by far the best all round CPU as you don't have a midrange GPU in your system.
Your best bet is the 10850k mate as martin has saidI'd be coming from an i7 930 4 core CPU at 2.8Ghz, built in 2010. I think any chip over £300 would be a stratospheric improvement over what I have, as mentioned!
Thanks, will read up a bit more on the 10850K.
