This will have almost certainly had a rear end shunt of some description, and the workmanship appears to be questionable at best.
Top tip: have a look at the stickers on the rear lights to see the date of manufacturer of them (you normally just have to open the little interior flap as if you were replacing a bulb). If the labels say the same as one another and a production date of around April/May 2018 - they're likely to be factory original. If they/one of them says a date after the date of the cars production, the car is likely to have been in a rear end collision, and I would bet been repaired on the cheap.
All the cars I've ever seen with badges in the wrong place have been in a rear end shunt at some point or, on some cars, the car has been wrapped or something.
