Isn't it the case that most charges go through the magistrates first, except for  those that can only ever be dealt with by the crown court.
Yes 99.9999999% of all Criminal cases start in the Magistrates courts. There are some exceptions around Murders, but in most cases even if a Magistrate or District Judge can't hear the case they will still decide bail and relevant bail conditions.
			I seem to remember reading that there are things that are too "trivial" for the crown court and will pretty much always be seen by the magistrates in the first instance and only ever see a higher court upon appeal (things like most motoring offences).
There are "either way" cases where the magistrates may be able to hear them, or if they decide (as in the instances that Dis is getting upset about) that they may exceed their sentencing powers they'll get referred up.
And those that are only ever seen in the crown court (although iirc magistrates may be involved in deciding if someone should be held in custody for more than the normal time).
A case being referred up is as Burnsy says completely normal and how the system is meant to work, it ensures that if the case is serious enough and the person is conviced the sentence is done correctly - but it's done before any assessment of built is made.
Yes, you have 3 types of case; Summary Only, Either-Way, and Indictable Only.
- Summary Only can only be heard/sentenced in a Magistrates court (there are some rules around Summary only crimes that can be sentenced/heard in a Crown Court when heard together with a relevant more serious crime)
- Either-Way where it can be heard in either a Magistrates Court (as a Summary Trial) or a Crown Court (as a Jury trial). And even if it is heard and the defendant found guilty in a Magistrate court it can still be sent to the Crown Court for sentence. In general, unless there are very complex legal matters involved if its believed a sentence wouldn't exceed around 12-18 months custodial it will be kept in the Magistrates court; however the defendant can always elect for trial by Jury as well so even if the Magistrates say its suitable for summary trial it may still be sent to the Crown Court.
- Indictable - Always heard in the Crown Court
			IIRC the maximum a magistrate can sentence anyone to is 6 months, so any case where there is the likely hood (or even chance?) of a sentence exceeding that upon a guilty verdict is referred up, and for many offences the sentence can be over quite a wide spread so you end up with "either way" cases where the offence potentially falls under either court.
Maximum a Magistrate or District Judge can sentence for a custodial sentence is 6-months for a single offence, or up to 12-months for 2 or more either-way offences. Outside of that it's at most 300-hours community service, and the power to hand down unlimited fines. I should also say that activating an existing suspended sentence doesn't count towards the above limits, however, only a crown court can activate a crown court suspended sentence.
As mentioned above an either-way case is still suitable for Summary trial even if we believe our sentencing powers as Magistrates won't be "strong" enough if the defendant were found guilty, provided we feel any sentence would fall within the 12-18 month custody range as we can always commit for sentence to the Crown Court. The reasoning behind this is that typically the legal issues are still suitable for summary trial, its just the sentencing powers that may be inadequate, and a trial can be heard a lot quicker in a Magistrates court than a Crown court.
			There used to be a blog run by anonymous magistrates that was great for explaining this sort of thing, as they'd go into how the court worked, give generic example cases of what happened and why.
I think you're talking about
http://magistratesblog.blogspot.com/ - the guy that ran it passed away a few years ago unfortunately as it was a great blog explaining what happens in the court.
One thing I should probably also highlight is that all Magistrate Court appeals are always heard in a Crown Court by a bench of 3 consisting of a Crown Court judge and two lay-Magistrates. In the same manner as a Magistrate Bench all 3 have an equal vote and an equal footing, the Crown Court judge is there to guide on points of law.
