My MVH Studios head strap shipped today. How long after shipping did you guys receive it?
Two days for me.
Looks good! I like the idea behind using the padding from the facemask! I've just used foam tape on those. My issue came from the sides being pulled in too far (narrow head) and being pressure points, but seem to have got around that now.
Something I do like about it, is that I can have it on relatively loosely for a lot of things (fishing for instance), but then can easily tighten it up and it still be comfortable, for gorilla tag.
Yeah, I am happy with the results so far, it's still not just right but much better than it was at Stock. I just realised something too, I should be able attach the VR Cover padding to the headband using velcro. Not wrapped around it like I have now.
And that is a good thing about it. It stays on even if a little loose.
Apparently, VR cover are doing a complete padded assembly for the MVH headstrap..... only 100 notes!ok, I spent the last few hours making changes to the MVH headmount and testing it out.
First I removed the supplied headband cover. It's so thin that it's almost useless!! Then I got my spare VR Cover and turned it upside down and placed it so that it covered the headband strap and most of the top strap. I fixed it in place using zip ties and some velcro strips. I got the velcro from two power cables, you know you see them attached to some power adapters for cable management. I am also using the stock strap to hold the weight of the Quest 2, I used a zip tie to attach it to the back of the headmount
It's only done very roughly at the moment. There are some things I have to work out. But, I tried it out for an hour and it was much better comfort wise and left no marks on my forehead!!
Here are some pictures, because I know I suck at explaining things
my mvh strap is here
took 3 days i believe
Apparently, VR cover are doing a complete paddes assembly for the MVH headstrap..... only 100 notes!![]()
My MVH head strap was shipped a week ago Wednesday and it's still not arrive. I emailed them yesterday but not had a reply yet.
I think I watched this for some kind of MVH headstrap review.... or something.![]()
The manufacturer also comments on how it should be worn.
