I’m pulling what little hair I have out with fan connection issue. I am new to PC building and this is only my second build.
I have 6 fans to connect to a Gigabyte 550i AORUS PRO AX, which only has CPU_FAN and 2x SYS_FAN headers.
2x 140mm fans from 280 AIO (X63)
2x 120mm stock fans (Top exhaust)
2x 120mm ARTIC P12 Slim (Bottom intake)
Do I need a fan hub/controller?
I thought I’d sorted it earlier, but apparently not.
how would you experienced people go about connecting this setup up?
Does anyone have a similar setup?
This is how I set it up tonight, but in the BIOS I was only seeing a reading on SYS_FAN 2? (Which are the bottom 2 Artic P12 Slim fans).I would get some splitters and plug the AIO fans into the CPU fan, the 2 stock fans into one fan header and the 2 x Arctic P12s into another fan headers. I use Argus monitor to control my fans (I don’t have as many as you though).
Im assuming the AIO wire is just a speed sensor and the pump is powered from a data connection so all 3 probably can.This is how I set it up tonight, but in the BIOS I was only seeing a reading on SYS_FAN 2? (Which are the bottom 2 Artic P12 Slim fans).
am I right in thinking the 2x 140 fans from the AIO and the 3 pin connection from the AIO cooler can all be plugged into CPU_FAN with a 3 way splitter?
thank you your assistance, it is much appreciated.
In NZXT software I was getting a reading for the pump.
I’ll turn it on again tomorrow and see how I get on, all fans were running before. I’m just not sure if I can set the speeds etc, in BIOS or elsewhere.
I've just downloaded SIV, and i'm still only seeing an RPM reading for SYS_FAN2?Grab Gigabyte SIV and use that to control your fan speeds.
I can try that now, I'm assuming that I should be seeing RPM for all 3 headers?The fact you are using splitters shouldn’t impact it, only one of the RPM wires should be connected.
Does it report RPMs correctly if you just connect one fan?
I'm getting somewhere, I'm now seeing the readings in SIV and BIOS for SYS_FAN1
The issue was, I was using the 3 way splitter provided with the CM NR200P (Comes with one red connection and 2 black connections). I was using the 2 black ones, I swapped one fan into the RED connection and now I'm seeing the RPM.
My AIO (X63) is connected to the CPU_FAN using the 3 way splitter that came with the X63. With 2x 140 fans and the 3 pin connector from the AIO cooler all connected to the splitter.
I've just tried it with a one fan only, still NO RPM reading.
Cheers for this help![]()
Yeah, I meant without the “higher” part!I am using the existing top. Its just...higher.
