May be an odd question, but what is the *safe* bend radius of a GPU Riser Cable? as i'm sure you can't just fold a 15cm cable in half otherwise the contacts inside the ribbon breaks/snaps.
Reason i ask, is because i'm still not satisfied with my new build and, i have been pondering of the idea of mounting my GPU vertically (so the ports face the top of the case.. basically where my reservoir is placed at the moment) and attaching a 30-50cm riser extension. This will involve multiple bends of the riser cable to make sure it loops from the back of the case to the front
pic for reference
https://i.imgur.com/Y5iw9fN.jpg
Any help appreciated.. as this would also help me with the length of cable needed.
pic for reference
as my plan for the Mini is not using the traditional vertical mount on the base of the rig, but actually have the GPU mounted/hung where the reservoir is.. That way you get to see all the computer parts as intended rather than have some covered by the GPU block in front. So i need a bracket made where the pcie slots cat fit into and bolted to the current mounting holes, then a pcie riser cable would be attached to it, routing behind the mobo tray to the front (follow pink dotted line).
