Still working fine here, might stay on these and avoid the 461's altogether
did you use the installer ^^?
thanks from Train01
no issues
I use it works very well. I like how it lists old drivers too so you can pick the driver version you want.
Just done a fresh install using this instead and seems to work ok so far, surprised at how much **** and bloat nvidia have, proper dodgy..... Pretty much unselected everything except the display and audio drivers
Really hope they get something new out as their drivers/control panel is beyond awful. Luckily not had any serious issues so far though.
Agree, I know AMD have taken lots of flak in the past but nvidia users dont know how poor they are until they see it.
Haha, so true. If you use NvSlimmer if can remove all the bloat before install, and you don't get that horrible telemetry, or driver overhead in the backround either. Recommend using DDU to fully unistall all current Nvidia stuff, then do a fresh install with NVSlimmer. https://forums.guru3d.com/threads/nvslimmer-nvidia-driver-slimming-utility.423072/
Oi. That is @illuz ‘ line.ChooCh00
If anyone wants to try them!
470.05_gameready_win10-dch_64bit_international
https://mega.nz/file/rE1E0JCS#-xL0bc6t2UiuiZ0Vtc-I9hcqGhV0UIr0B6FKJcdy_kE
Mine says the same thing, but if you click on the 'Look Up' it says DX12_2 on the website.
https://www.techpowerup.com/gpu-specs/msi-rtx-2070-super-gaming-x.b7142
Can it run starcitizen?
Lies... and slander.
