p I am undervolting with a curve, currently runs around 1875 core with 875mv. Going to see how low I can go with that.
No detectable coil whine.
I settled at 1900mhz core at 850mv with a +500 on the memory.
Forgot about TROH.@Kaapstad ty
Superb card so far, because its got pretty much all the performance I need at 1440p I am undervolting with a curve, currently runs around 1875 core with 875mv. Going to see how low I can go with that.
Looks like MSI are swapping to a metal backplate instead of plastic to help the miners![]()
Around 150 is good spot. Your cpu is definitely holding the gpu back.3DMark is similar to mine with a 2700X, not tried Warzone, downloading now.
*edit, installed.
1440p, high settings, 100 FPS+ in solo battle royale. No idea what I should be getting, dont play it.![]()
What power issues if I may know.For me been fine, I went to 461.81 to see if would fix the power issues, turns out the power issue was caused by something I did on my pc, but I havent noticed issues that some have reported like audio stuttering so staying with it.
2d clocks? You mean it’s dropping below boost of 1710 under high performance? I had worse scores with high performance so I went back to default. Is this an issue?It was just that setting prefer max performance was not sticking, and games kept dropping to 2d clocks, but it was down to something I had running on the pc.
Better off just using a frame rate lock if the game doesn't require all the juice
The card ramps up and down (clocks and voltage) depending on the strain so a frame rate lock would have the same affect but with less faffing around
How old we talking since I play a game from 2002 now and again and never had an issue with clocks?Noticed some issues on my 3080 in the drivers.
"prefer max performance" allows card to go to idle clocks, on my 1080ti and older cards it didnt, so in fable anniversary an old game I am getting stutters as game keeps moving between 2d and 3d clocks.
