Deleted User 298457
Deleted User 298457
Nor want to give away desk space to unnecessary borders, hot keys, blah.Not all of us have huge houses or rooms.
You probably don't have both languages installed on the keyboard.
As long as it doesn't keep you up at night, that's the main thing.How do you sit at a desk smaller than a normal keyboard?
I think it is more for a minimalist look rather than people having 20cm desks due to lack of space TBH.
Bought a new set of fancy pants routers (ASUS XT8 2-pack). Have had an ethernet cable installed from the front of the house to my office.
On the loo at the back of the house (furthest bit away from modem and on a different floor) and very happy with my new speeds.... this is just on the 5.2gz-1 and not even the wifi6!!
Sure. I have virgin media fibre optic broadband, with their 500mb speed broadband (which is their fastest other than their 1gig option which isn’t available on my street unfortunately). To find out what you can get go on their website and type on your postcode. I think we pay £45 a month.Can you go into some more detail about your setup? Who is your internet provider? What were your speeds before? How have you set this all up? I need this sort of wireless speed in our very old, victorian house.
The “internet wire” from the outside world goes into the Virgin Media home hub 3. I have set this up in “modem only mode” (so no WiFi coming out of this).
I then bought the aforementioned router 2 pack (which is available for £400-£450 but there are no doubt cheaper alternatives).
There is an internet patch cable going from the Virgin Media Home Hub into the first router.
There is then a patch cable going from the first router into my wall connection.
The wire in the wall goes up through the plaster, through floor boards, through a wall and into my office. I’m having various plugs installed in the upstairs rooms so got this done at the same time. My new office has 12 plugs! Need to do a fair bit of replastering though.
From there, there is a patch cable going into the second router in the office (at the back of the house). These are set up on a triband mesh network which also uses wifi6 (but only very modern devices use this - my two year old iPhone does not, yet still got the 500mbps speed).
Hope that helps!
I should add, that I get excellent WiFi speeds from the routers without the hardwired Ethernet backhaul, so this may not be necessary. The thing is though that most routers sets seem to use WiFi 6 for the wireless connection between the routers, so it hogs the best WiFi signal. By having the wired connection, it frees it up.
Bottom line is that you probably don’t need the hardwired Ethernet connection.
Yes, the downstairs router would connect to the upstairs one via the dedicated wifi6 channel. Really, they aren’t actually very far away in my house (front of living room to back bedroom in a semi detached so actually about 5m away albeit behind a steel girder) so it might not work so well in a big house.So the downstairs router would just connect to upstairs via WiFi? And if you were upstairs you'd connect to the upstairs router? Suppose it would need some tinkering and testing. Will definitely give it a go. Cheers mate.
