Enter the gungeon gave me hundreds of hours of gameplay. (If you’re into that sort of game, a bit like Isaac with power ups and synergies etc)
Same here.roguelikes are the one type of game that has sprung up everywhere and i simply don't like them.
I know what you mean.I think a lot of the fuss is made by people who don't understand that unless something uses totally passive cooling then there will be some sort of noise.
It'd audible and a little frustrating, seeing as the Xbox doesn't have these issues.
All consoles suffer too, just some are worse than others
I don't have coil whine on my ps5 and the x didn't have it. Both fans are audible, I think the x was a bit quieter but neither are loud at all thankfully.
Mine buzzes. But only on certain games. I find borderlands 3 the worst culprit. Even then it’s not overly loud that it annoys me. The PS4 pro was WAY louder.What games you playing?
There's no buzzing at all?
Nothing similar to this - https://youtu.be/WIHAqCQL-g8
I think it’s coil whine. Because the pitch of the buzz changes when scenes change in game.Yeah the PS4 Pro in had was the newer 7216B and that was still loud.
Buzzing is the same for me. Different sounds in different games. Not sure what or why that would be.
Is it coil whine, or just fan related?
When I load BL3 and get to the main menu, the ps5 is buzzing. But the buzzing stops momentarily when the game micro freezes, as the game applies the hot fix patch. It’s hard to explain but if you’ve loaded the game up you’ll know what I mean.
