- 10 Oct 2006
Just priced mine up at the local F1 centre. 2x 225/40/19 & 2x 255/35/19.
After discounts comes in at £618. Should be able to drop that by another £8 as that includes disposal of my old tyres (runflats) which I want back as the still have 4-5mm all round & can sell them on.
UPDATE
Had a chat with Kwik Fit this morning & they have offered the same tyres fully fitted for £578
One thing I noticed, they have the same tyres listed 3 times, only difference I can see is fitment is listed for Ford, BMW & Hyundai
Ford fitting is £30 cheaper, but as far as I can see the tyre is identical. Any idea why this would be?
For £30 go with the BMW star rated tyres (assuming it’s a BMW you have the run flats on). I’ve just done the same swap and when reading up on it a few owners commented the star rated tyres have slightly different tread profile on the outer edge of the front tyres to suit the wheel alignment of BMWs. I take this with a pinch of salt as no one posted a picture but for the minor price difference I stuck with the star tyres as it may save hassle if I have a drivetrain issue where you bet if you have no star rated tyres they will blame them first.
The road noise and ride are noticeably better than the Bridgestone run flats I had on.
