Ok how do I play Alyx on my quest 2? I need the virtual desktop thing too?
Right, well that's the graphics card upgraded! Thanks to the amazing deal from ocuk, I've now got a 6700xt on it's way. Got to try out squadrons with the xbox controller I guess.
1070ti.
Yes, because they're two different products.I bought Virtual Desktop for my Rift years ago do i need to buy it again for my Quest 2 ?![]()
Whelk erm to the OA Sis!
I tweaked settings until I could get it to 90 most of the time. I don't may it often but I can't make myself okay it downstairs on console anymore. It's a different game in VR.Folks any players of Star Wars Squadrons?
I am using Oculus Link cable with the Q2.
The frame rate is not bad but hte Oculus tool is reporting 45hz which doesnt seem right to me surely.
Any special settings I should be aware about?
Squadrons seems really weirdly optimised. Even on a 3090 I have performance issues sometimes.
The main thing is to turn down all the settings for the 2D mode, as for some reason the 2D and VR renders are completely separate, so it's effectively rendering the game twice, instead of just copying the pre-warped VR image from one eye, which what most VR games do.
If your game is showing 45fps then you're actually reprojecting, as the headset is halving the framerate and interpolating the frames. The Oculus version is called 'Asynchronous Timewarp' and it actually works very well, but you may notice some visual artefacts.
For flight and space sims I'm using an X52 Pro.
