- 19 Jan 2006
Does your PC/motherboard definitely have bluetooth with all the correct drivers installed? It's normally part of a WiFi module if I remember rightly.
Add on a wrist rest of you have the budget.I’d been looking at that actually. The shipping is surprisingly reasonable. I’ll give it a go, thank you
My Keychron connects to the PC fine with bluetooth, though I just plug it in most of the time.
Dont know if yours is the same, I have a K8, but its quite high so I bought a ROG wrist wrest, think your keyboard may be a little smaller though.
KEMOVE for me. used a few now in customer buildsFair enough. Not an issue I’ve ever come up against tbf.
Which do you think is better - KEMOVE or the RK61?
hahah i do this with mice... and now phones. have a spare xperia 10 ii if youre interested! EeeeeekkkkI’m just thinking maybe I’ll order two and send one or both back - the KEMOVE dolch, shadow, and the RK61
I'm finding the keyboard latency really quite high. Seems the same wired as wireless. Any idea why this might be? I have the red switches that are supplied with the keyboard.
Also, any idea how to fix the keyboard doing things like bluuuuuuuuuueeeeeetooooooooohhhh
I found some nice white cherry ones but this was in China. A quick Google should bring up most white ones I'd imagine though?A bit of a coincidence because I've just spent around two hours looking for a UK layout wired keyboard in WHITE.
If anybody has got a name (if we can't link) then I'll appreciate it.
It must have the layout like the one on dirtychinchilla's Logitech above or this one (it must have the 3 keys to the right of the L key) - https://en.wikipedia.org/wiki/British_and_American_keyboards#/media/File:KB_United_Kingdom.svg
im confused the same dongle in the laptop? rf should be better than btI think I’ll have get a decent Bluetooth module. Considering what a pain it was to get my keyboard connected, I don’t think my motherboard’s module works very well. No problems whatsoever with my laptop.
