Consoles r poop!![]()
I would rather play on a PC than a console, I have a 4970k @ 5GHZ and a 3090FE, and I will not upgrade till at least AlderLake if it pans out well.
8 cores are minimum? You're a bit exaggareting
But I do think the IPC power of new consoles will surely ruin a lot of CPUs, anything below 5600x, and even 5600x itself
i see pc master race people on subs claiming 3600 is faster and has more cache, and with superior, low-level console CPU optimization, even a 3700x will be nowhere near what series x/ps5 cpu can achieve.
Since no one can run ac odyssey/rdr2/horizon zero down with 1.6 ghz 8 jaguar cores at 30 fps. at best, you might get 20 fps, and at worst it will drop below 15 fps. that's how much developers can squeeze cpu performance out of consoles. apply that logic to 8 3.5 ghz zen 2 cores, and see how even a "5 ghz" 10900k crumbles under it
yeah but gotta factor in ipc as well4 and even 6 core cpus are struggling to drive RTX3000 GPUs, HU benchmark data speaks for itself
Should have bought a 6700xt you would have higher framerate
I would rather play on a PC than a console, I have a 4970k @ 5GHZ and a 3090FE, and I will not upgrade till at least AlderLake if it pans out well so not sure why you feel Iand other cannot game on a 4 core or even 6 core.
I have had this since 2013-2014 instead of upgrading nearly with each new CPU/Mobo/GPU like I used to do.
Look at the TimeSpy I uploaded in someone's thread, double the FPS that Humbug gets in BF4 @ 1440 Ultra (180FPS AFAIR).
noooo how dare you continue using your old cpu1!1 how dare you get %99 usage!! turn down to medium or high-medium mixed settings to make it bottleneck!!I seen it, also the bottleneck at 1440p is about 14-17% going by the tools you can use online
Either way nothing is worth upgrading to as I am not struggling and have a backlog of games from past few years, I get very high FPS in nearly all games and no less than 90FPS is some poorly optimised games.
RAGE2 1440p MAX like 200-240+FPS most of the time.
I no longer watch those YT channels as they are normally full of you know what esp Linus with his videos like high speed ram does not matter in games then a few month later a total backtrack (a sell out).
I do not do MP period, I will again have a top CPU when one is worth upgrading to for me if I cannot get good FPS at 1440p with max settings in most games.
240FPS in Rage 2 ok for you?
Any sign of AMD dropping their prices to be competitive with intel yet? I refuse to pay £300+ for a 6 core 5600x let alone £400+ for a 8 core 5800x........
