- 1 May 2013
- M28
Wherever you were up to in the demo
So you dont get the option to change class? Played through as the Technomancer but wouldn't mind trying out the fire fella.
You can change. When it loads you to the character you were on, hit Esc and it takes you back to character select and you can make a new one. You will start right where the demo started, with the option to skip the prologueSo you dont get the option to change class? Played through as the Technomancer but wouldn't mind trying out the fire fella.
taYou can change. When it loads you to the character you were on, hit Esc and it takes you back to character select and you can make a new one. You will start right where the demo started, with the option to skip the prologue
Having it stutter like mad here. https://steamcommunity.com/app/680420/discussions/1/3075370188227926941/?ctp=3 Few fixes/work arounds.
Only another hour before I get out of work and then another quarter to get home. You lot better not have finished the story by the time I get home
I can think of very few games with both 12 and 11 where dropping to 11 hasn't been miles betterCan confirm going from DX12 to DX11 elminates a LOT of the stutter. Still get it periodically but no where near as much. That and uncapping FPS makes it a clearer due to the resolution scaling.
The story storyStory, what story?
Looks like a rip off of the division games and gears of war
PC specs revealed now
Minimum (720p)
Recommended (1080p)
- OS: Windows 10
- CPU: Intel i5-3470 / AMD FX-8350
- Memory: 8GB
- GPU: Nvidia GeForce GTX 750TI / AMD Radeon R9 270x
- DirectX: DirectX 11
- Storage: 70GB
Ultra (4K)
- OS: Windows 10
- CPU: Intel i7-7700 / AMD Ryzen 5 1600
- Memory: 16GB
- GPU: Nvidia GeForce GTX 1060 6GB / AMD Radeon RX 480 8GB
- DirectX: DirectX 12
- Storage: 70GB
- OS: Windows 10
- CPU: TBD
- Memory: 16GB
- GPU: TBD
- Storage: 70GB
