- 19 Jan 2007
- Up a Tree
You always seem to get the good cards too, well done I say.
Well volunteered Th0nt
Perhaps we should all standardize on a benchmark as well. Like listing the settings as well...resolution etc.
Mine runs about 2300 if left alone.not changed anything on mine
just ran a benchmark and mine sat at 25xx topping out at 2555
How are you doing that? Which software? Radeon doesn't even give me the option to go that high. Not that I'm complaining with what I'm getting out of it.
I use adrenaline software (Radeon drivers) min Freq 2830 max Freq 2930.
Installed my sapphire 6700xt couple of days ago. Noticed while playing cs:go there is very bad coil whine. Any ideas what my options are or if I can fix it some how?
Got my new Powercolor Fighter 6700XT now, this one seems to work fine, the one I got last Friday was DOA so this is the replacement, just running it through it's paces.
The wife now has 6700xt goodness to go with my 6800xt - just need the big boy to complete the set
Paid a bit more than the OCUK deal but only £20 or so more so was worth a punt![]()
OcUK have spare one lying around then or did PowerColor assist?
Awesome, the Vince!!
Meccano car instead of the Haribo?![]()
Right now i still haven't fitted the 6700xt as the wifes machine is currently rocking the 7!That sir is legoRight now i still haven't fitted the 6700xt as the wifes machine is currently rocking the 7!
Time to move the 7 onto a dedicated rig then my friend. Are the Baffin's still going well?
