Incompatible or not good enough? Mine doesn't recognise my 6700xt but it still plays.
Haven’t tried PTC before but that gives 1.6Gbps currently.So if V27 is borked is the latest PTC version any better?
Mine says that with the 6700 xt, works fine when firing up a game, anyone know if it's possible to turn the warning off?
I've managed to get rid of the error message. I tried a few things at the same time so I'm not sure which sorted it.Same here, think it's just the software not recognising the gpu, and therefore assuming it's not upto the grade. It all works fine.
The point I am really trying to get to is that Link isn't working. I've run a speed test and I get a cable speed of 1.1Gbs which seems standard and also confirms the cable works and the Quest 2 can communicate with the laptop.
The symptoms are... I select 'Link' from within the headset, the headset goes black with the usual three white dots for about 5ish seconds, then the dots disappear leaving a black and blank screen inside the headset and after another couple of second I am returned to the Quest home menu.
The port on the laptop is a USBC with display port capability.
That speed is far from standard it normally 2.1Gbs or more with the oculus link cableI've run a speed test and I get a cable speed of 1.1Gbs which seems standard and also confirms the cable works and the Quest 2 can communicate with the laptop.
what PTC ?So if V27 is borked is the latest PTC version any better?
what PTC ?
Thanks...Opt in to public test channel, ie beta. Sometimes good, sometimes bad.
Be interested in how much bandwidth is actually required. To stream compressed 4K video 35Mbps should be enough but that’s at much lower framerate, plus its 2 x screens, then there’s tracking and controller comms
Think that how i setup my quest 2 it connects to the wireless hotspot on my PCdec 2020 so might not work now ?
But i didn't go through doing all that stuff i just set my PC to be a wireless hotspot in the windows software
(I have it set like this because my PC motherboard wireless is faster then my router wireless )
