Don
- 20 Oct 2002
- Oxfordshire / Bucks
got it going
slow as hell though
slow as hell though
got it going
slow as hell though
thanks
says over 855Mbs in VD menu
connected directly to PC, says 333Mb/s I think
both 5GHz band
how do i check if its throttling back?
Hi All.
Just picked up a quest 2 and so far loving the versatility of it. Think I have settled on Using virtual desktop rather than PC link as it just seems to work...
What are people doing about battery usage on wireless? seemed to only get maybe 2 hours playing wireless... can you have it plugged into the wall charger and play at the same time? I do have a battery bank I could attach to it but that will get a bit heavy especially for the two kids.
Sorry Shi Warrior, wasn't online yesterday.
That seems like it's connecting at 5Ghz and not been limited. Which is strange.
Are you connecting your PC to your Router using Wifi? or are you using a network cable? If you are using a network cable, then it doesn't matter what Wifi Speed your wireless Router has. If you have your Hotspot setup correctly on the PC, the Quest 2 shouldn't be connecting to Router at all.
So, my question is, how have you created the Hotspot? I mean what are you using, A Wifi PCIe adapter? USB adapter?
Do the kids play for more than 2 hours consecutively? You can attach a powerbank to the rear of the headset, it can actually increase comfort by acting as a counterweight.
Not usually as they are only young so don't want them more than 30 mins at a time.
hey no worries, hopeing that someone would reply whos used VD, no matter
i have wifi 6 on my motherboard
if i go direct to PC, i switch on wireless hotspot in the network settings from the taskbar
Do you have another machine or a spare drive to try? I had a load of issues trying to get link to work. I had two cables including the official oculus one, and like you I could see the Q2 on my PC and could access the files. I also had the link option in the Q2 but it would not work. I ended up taking the headset back, and the new one also failed to work. It turned out there was an issue with windows 10 and a reinstall of the OS sorted it.
Thanks... I have raised an Oculus support ticket. I'll kepp everyone updated incase the information is useful to all.That speed is far from standard it normally 2.1Gbs or more with the oculus link cable
But the latest Quest v27 firmware has knackered the Quest link speed somehow
Try restarting headset and laptop. I get that sometimes, just attempt restarts.
Same here, think it's just the software not recognising the gpu, and therefore assuming it's not upto the grade. It all works fine.
Hey guys. Question. Does VR gives motion sickiness? If so, how bad is it?
