- 14 Apr 2014
- Hampshire
Wait until you get to the NVME drives - so much quicker than SSD.
Also HD's will affect FPS to a degree, if, when running around you are dynamically loading then you may get blips which may get annoying.
I'd agree with a lot of other posters, verify the drive is okay - assume you've done the Steam verification as well? If you can afford to then a SSD / NVME drive would be a good purchase.
M.
I switched from 850 and 860 EVOs to MP600s and WD Blacks - haven’t noticed any change at all.
I’m sure I could measure it, but I can’t perceive it.
The first jump to SSDs is the greatest perceived change.
