The Radeon RX 6800 (XT) Owners Thread.
i doubt you will see much difference to be honest, depends if you think the cost is worth the extra 5-10% if that performance; at 144 fps does it really matter that much? you wont see any more performance with the frame limiter on so not really much point to be honest. remove the limiter if you want more frames
Any owners use an 850w psu together with 5600 or intel equivalent? Is it enough power wise?
So long as it’s a high quality PSU with a strong Amp rating it should be fine. I’m using a Fractal Platinum 860W with a XFX 6800 XT and a 5800X. No problems.
I run an 860w Seasonic Platinum Series with a 180w TDP cpu and the 6800xt. Haven't had any issues at all with mine. I just took out the 7 shoved this in the slot and away we went. Didn't even reinstall the drivers.
@Stanners @Vince are these new toys beating the 6900's then? :D
TBH I want that one as well to complete the collection. a nitro + / toxic would go down very nicely but you cant have it all so this little fella is fine. Mine will do pretty much 2.7ghz and is super quiet so thats good enough for me for now!
I’m getting about 16600, 18200 GPU, 11500 CPU with a 6800 XT and a 5800x. But then I have thought mine were a little behind, but everything plays just fine so not too fussed. I would say yours is ok? I’m not sure how some of those scores are happening frankly unless people are seriously tweaking.
this card has been nothing but trouble for me i have Gigabyte Radeon RX 6800 XT GAMING OC and i keep getting black screen crahsers at first i though it has just a warcraft problem but itds doing it in other games, tried all the usual stuff reinstaling drivers and windows changing power cables factory reset to the card
going to try and contact customer service hoping that i am still in window for a refund (not bought from here btw)
this is the second times i have ever bought a amd graphics card and like the first its been nothing but trouble i dont think ill ever buy amd again
That's a real shame, occasionaly you do get a duff one - In contrast mine has been flawless since putting it in :(
What PSU are you using?
Do the same crashes occur when you run your system at BIOS default settings with no OC applied to your CPU or Memory or GPU?
Corsair RM850x 850W 80+ Gold Modular Gaming Power Supply
I dont have any overclocking on my CPU or GPU. GPU temps sits around 40oc at idle i updated to the lastest bios the other day
it works fine when i am just browsing the web watching videos but as soon i load up a game it just starts to black screen its inconsistant also i can go for afew days without issue but this morning its just black screens and i have to forse a resewt to the pc
