well, it's not a clickbait video. it also contains a valuable 3600x data in watch dogs:legion.
there's no point discrediting zen/zen+ cpus' lesser performance. this is a general issue that can happen with ANY cpu. it's not specific to lower end, or mid range cpus. in any cpu bound situation, it will happen. and yes, a 5600x/5800x/10900k can easily be CPU bound in current games such as wd legion, cyberpunk, cod warzone and other certain titles. Ray tracing adds an extra CPU load due to BHV structures. This is a serious matter that will affect a 5800x sooner or later. Games have different regions that can be heavily taxing on CPUs. Take AC: Odyssey for example, it's really hard to achieve locked 60 FPS in the Athens region. This is just a simple example, you may argue that these are badly optimized games, but PC is full of them.
you may save the day with 5800x, but then a 4080 will come out and outperform a 3090. and suddenly you will see that you're affected by the driver overhead now, and a competitor AMD gpu gets higher frames than the 4080 with your 5800x.
in the same data, you can also see 5600x is maxing out at 140 fps with a 3090, while rx 680 have no trouble delivering 157 fps, and 6900xt delivering 167 fps. this test is labeled "watch dogs legion 1080p medium", so it's not a GPU bound, but CPU bound situation. now i know, i said myself, no one will play these games at 1080p medium with these GPUs. that's an entirely different topic. please don't bring that up. i'm aware. but reality is there, even the 5600x performs worse with top Nvidia GPU compared to lesser AMD GPU. You can clearly observe %20 more overhead with the Nvidia GPU in this particular game, and on other certain games. This overhead can be near zero, can be %5, can be %10, and can be brutally %30 in some games. So no: you can't discredit this serious problem as a lower-end CPU issue.
see the video below. a 5 ghz 9900k can become CPU bound at 50-60 fps in cyberpunk with maxed out ray tracing, and high crowd density. yes game is horribly optimized, but a potential amd gpu will have %20 more CPU bound performance there, if the overhead is %20 for this game. it is yet to be tested, and i don't expect anyone to test it out, because to get 50+ fps with maxed out ray tracing with an amd gpu, you need to lower the resolution to 540p-720p or something. if someone has the right combo, they can test it. sadly, i cannot. but i bet 9900k would be able to stay above 60+ fps in this particular scene when paired with an amd gpu, if the gpu settings are set to low resolution appopriately to prevent gpu bound situation at lower frames.
