- 1 May 2003
Anyone noticed that there is an ongoing exploit for CPUID (CPU-Z), all versions up to V1.81?
I was quite surprised how many 3rd party applications/tools are using this as part of their CPU monitoring tools.
https://www.cvedetails.com/cve/CVE-2017-15302/
Exploit: https://github.com/shareef12/cpuz
If affects all Windows OS from Win XP - to Win 10 v1609 which I think is the equivalent to Windows server 2016.
For example Corsair iCUE uses CPUID version 1.50 which is affected. Users need to stop this corsair service in services.msc to remove cpuz150_x64.sys from the temp folder.
In CPUID CPU-Z through 1.81, there are improper access rights to a kernel-mode driver (e.g., cpuz143_x64.sys for version 1.43) that can result in information disclosure or elevation of privileges, because of an arbitrary read of any physical address via ioctl 0x9C402604. Any application running on the system (Windows), including sandboxed users, can issue an ioctl to this driver without any validation. Furthermore, the driver can map any physical page on the system and returns the allocated map page address to the user: that results in an information leak and EoP. NOTE: the vendor indicates that the arbitrary read itself is intentional behaviour (for ACPI scan functionality); the security issue is the lack of an ACL.
