- 20 Oct 2008
I think this one is downstairs to upstairs.
Waaa? Wifi can sort that.
I thought he digging to office that at back of the house in garden
proper mesh solutions
Wireless, but this was at previous propertyHow are the nodes connected? Wired or wireless?
wifi backhaul is bad.Wireless, but this was at previous property
At 900Mbps?
I’ve spent a lot of money on proper mesh solutions and the only stuff that’s going to hit 900Mb is WiFi 6 Netgear Orbi, and they’re mega expensive.
I do over 900Mb between upstairs and downstair using a pair of AX3 wifi 6 routers with 160Mhz channel. they were very cheap, less than the prices for wiring being quoted here, still wired is better and wires will be compatible with faster speeds as they inevitably arrive, depending on quality of cable you might be able to run upto 10Gb over ethernet but at the very least 2.5 or 5Gb.
https://forums.overclockers.co.uk/posts/34600074
Note that post is to LAN devices connected to the wifi APs, wifi devices connecting to the same bridge are slower due to repeating signal and the AX3s having no backhaul.
They connect over the wifi channel in a standard way, so would be limited in a wifi congested area as there are no extra channels for backhaul which is what the pricier gear does, you can wire a backhaul on these APs for extra performance of wifi connected devices so it doesn't have to repeat which knocks out speed due to back and forth comms but doing a point to point link wifi ap to wifi ap its pretty quick with 160Mhz channels as shown, limited by the LAN port.
definitely wired is the way to go, but if you are stuck wifi can do GB LAN speeds, I still plan to wire mine at some point though.
These Huawei are great performers but they are cheap because they aren't brilliant software wise, lacks a lot of features that something like Asus or netgear etc. have, plus some of the features it claim to have don't work well like parental control or guest wifi but its core feature of fast wifi 6 it does fairly well.
So wouldn't recommend if you need all the bells and whistles but if you want to add cheap wifi 6 to something it is fine.
If you move your house closer it might be cheaper.
