Can anyone recommend a airless paint sprayer? Need to repaint my fence, prob 20ish panells maybe more.
This one on screwfix seems to have good reviews
https://www.screwfix.com/p/wagner-2369472-460w-electric-fence-decking-sprayer-220-240v/7305r
I've got that one and it is excellent
brilliant thanks.
will pick one up and a couple tubs of paint whilst its on sale.
quick question tho have you tried using it to paint indoors? Interested if it could save the bulk of room painting in the future
That screwfix one has great reviews so would be interested to hear your feedback if you go for it as doing the fence and shed in the summer.
I think I need one of those. I've got about 25 panels roughly and it took me a very long time by hand. What do you do about concrete fence posts? Tape them up?
theres still overspray but i will go round with the jetwasher once its dried should get it off
The only problem with that is I think the concrete post will draw in the paint and it wont come off (I got some on my patio and it wont come off). If you hit the fence with the pressure washer it will likely take the paint off the fence so be careful![]()
Got a Henry the other day....best power tool I've ever bought![]()
A piece of cardboard held in your other hand as a masking shield should work fine. It will certainly prevent the majority of overspray, leading to minimal clean up.I think I need one of those. I've got about 25 panels roughly and it took me a very long time by hand. What do you do about concrete fence posts? Tape them up?
