 - 21 Oct 2004
 - Wales
Yeah i've looked at the post and I got the 5800x's temp under control a while back using a combination of EDC/PPT/TDC limiting and curve optimizer settings.
I have however been keeping up with the 5800X issue of running hotter than the other SKU's and I ran into this explanation (Update: Stilt worked for asus and didnt make dram calc/clocktuner, thanks Gee for clarification)
Source: https://www.reddit.com/r/Amd/comments/kn1wnj/ryzen_5800x_temps/
This SKU has the highest intensity of the whole Ryzen 5000-series line-up, it being a single CCD SKU with a 142W default power limit, the same power limit that is normally given to CPUs which have two CCDs (i.e. twice the area to transfer the heat out from).
On top of that, it seems that higher SIDD (static leakage) silicon is more commonly found in this SKU, which makes it run even hotter in relation to silicon with lower leakage characteristics, even at the same exact power dissipation.
TLDR: The CPU die is so tiny relative to the amount of power it dissipates (i.e. high intensity), that you cannot effectively transfer the dissipated heat from the die to the ambient air (through the radiator), no matter if you are using the best custom loop money can buy.
It's physics and there is not much you can do about it. Improving the cooling helps to a point, but won't change the basic behavior, that is the result of extremely high intensity and maybe partially the higher leakage characteristics of the silicon that maybe tends to bit a bit higher in case of this specific SKU.
