Excellent exercise and you save money. Win win![]()
Spinal surgery here I come yayyyyy
Anyone got a pole saw like these/what are the cheaper offerings?
Also going to get a seperate hedge trimmer also
https://www.powertoolworld.co.uk/ma...UVLAY2TSYmTIXd-_xVrj9Iltx63vFMARoCOIAQAvD_BwE
wasnt bothered with cordless as we have sockets both ends of garden theres no need for us.i have this one.
https://www.screwfix.com/p/mac-alli...240v-corded-electric-pole-hedge-trimmer/6928r
its been greatwasnt bothered with cordless as we have sockets both ends of garden theres no need for us.
I have this one with the extra long reach bit. https://shop.tooltalk.com/products/...snZ-0zpenYx1d94SM-3dd3OHl0BXzv1UaAuOREALw_wcB
works absolutely fine. Use a battery converter for myDewalt batteries.
That's not a pole saw that's a pole trimmer.
I got the screwfix cheapo one for £40 the pole saw that is and it's cut through 7 tree trunks so it would eat branches alive.
Obviously a saw is much more powerful than a trimmer and corded is brilliant for power. I have a 30 metre outdoor extension so cordless isn't needed for stuff like this, cordless is better for smaller jobs.
At risk of contradicting the point of the thread, but at that price/your interest level/the extra equipment required to get the height; is it a job worth out sourcing? Looks like a couple of full days potentially!
Thanks, good option, just working out if I would benefit from the additional angle to cut the top of hedges (pic of back garden below, but I have similar at front also)
Not sure if the 90 degree angle element is worth the extra money
Ah yes, I meant pole hedge trimmer. Corded tools wont satisfy, I need it both front and back, and back is approx 45m. Im in favour of cordless also as it just makes the job quicker and saves running an extension.
I've never had an issue with my cordless angle grinder or cordless saw
On the saw front, just treated myself to this: https://www.powertoolworld.co.uk/ma...-brushless-hedge-trimmer-inc-1x-5-0ah-battery
I measured my current (corded) trimmer, a £60 qualcast one and it was ~670mm lenghth so I wanted to match at least that if not more.
As you can see from above the garden will keep me busy, and I'm not particularly green fingered!
I dont want to chop them completely, just keep them trimmed (so maybe slightly neater than the photo).
I'd rather pay the tools than pay for labour as imagine it wouldnt take long until you've made up the cost of a tool and it's relatively easy labour.
Oh, would help if I read properly/ it had another pic! yes that sounds ideal ! Just got to look for a makita> ryobi adaptorThe ryobi does angle to about 80 degree or so, not sure if that's what you meant.
I have about 5 batteries so not a problem, but in my experience the other tools last a long time with 3Ah or 5Ah batteries. only time I've run out of battery is sawing through knots in sleepers with the disc saw (up the torque so ups the load). Ive got the drill, impact driver, flashlight, saw, angle grinder, multi tool and lawnmower (not tried lawnmower yet)I don't see how cordless is quicker on a 45m long garden. Surely it's going to require multiple recharges?
Cordless has its place sure but for big jobs corded usually wins in every category especially price and power. .
