Cpu Upgrade
Intel 6 Core i5 11400F Rocket Lake CPU/Processor
ASUS TUF GAMING B560M-PLUS Intel B560 PCIe 4.0 mATX Motherboard
Corsair LL120 RGB 120mm Dual Light Loop 1 Fan Expansion Pack
Corsair 8GB DDR4 Vengeance LPX 2666MHz Memory Kit x 2
£411.24
Or
Intel Core i5 9400F 9th Gen 6-Core Desktop Processor/CPU - No iGPU
using old motherboard and then also upgrading ram to 8gb x 2
£140 plus ram upgrade
OR
Intel Core i7-8700 Retail - (1151/Hex Core/3.20GHz/12MB/Coffee Lake/65W/Graphics)
£229.99 plus ram upgrade and maybe new motherboard
You can get it on a well known 2nd hand high street chain's website.
Sounds like KEX
Lol found It,
so am I right In thinking I power off pc, take out the old CPU and drop this one In the boot It up or do I have to swop It out then do a bios update ?
Whilst I’m upgrading the CPU would this ram upgrade fit
HyperX FURY Black HX426C16FB3K2/16 Memory 16 GB Kit*(2 x 8 GB) 2666MHz DDR4 CL16 DIMM 1Rx8
So I’d upgrade from 8GB to 16GB
Can do. I would suggest to get the cheapest ram that is 2666 and above (it may be that 3000 or 3200 is cheaper as they are more common speeds - but they still can run at 2666 as well
Got all the bits today so put It all In, took me ages to fit the new cooler as not much room, pc started It recognised the new CPU and went to bois screen where I went with defaults and all seems well.
Many Thanks All
Now need to find a 2nd hand GPU better than mine now lol
