Messed around with that freebie Dell server today. Only stays on for a few seconds then turns off. 1 Time it did actually stay on and post it complained about a memory size being wrong but I had no keyboard in so couldnt go and further.
Got my P2 350mhz running at 392mhz. Seems very stable. Bit scared to go 133mhz fsb as that would be a big increase over stock!
Did gain me ~300 points in 3dmark 99.
Would very much like that mate but cant keep letting you send me things for nothing!I've got a 550 with no heatsink you can have if you want? Found it out today in a box of stuff.
Thanks a lot mate!I ain't going to use it mate. I'll pop it in the post sometime in the week.
Haha thats hopefully now doing something useful like being melted down into tin cansYou can repay the favour by taking @cee-S-dee to a hot hatch car meet in your Mégane.
That has to be one of the ultimate dos/win98 machines possible.
Slot loader too!
Very nice machine mate
Your CRT looks monstrous on that case! I have my slot1 machine in the same case so know how big that is!Thanks mate! I'm really happy with how its turned out. This combined with my Tualatin machine, I think covers pretty much everything I'd want to play.
Beast of a machine!Added a SB Live! to the machine today. This thing is pretty much full now. To make space for the live, I removed the bracket from the Matrox M3D and placed it in the PCI slot shared with the ISA Slot. Installed the Live! using the Audigy 2 Drivers, but not installing any of the SB16 Legacy stuff as the Awe32 covers that. The Live is to handle purely the Win98 Sound duties. I'm really pleased with how this machine has turned out, and its pretty loaded in regards to sound now (Live, AWE32 (Korg DB), TB Malibu, MQ Midi Card with DBX2, and all the external modules attached to the MQ Card).
haha, thanks for that!Good card and monitor. Yes that was the one, UniRefresh and it washaha, thanks for that!
It sounds like once its all setup correctly (which I expect took some time) then it all works very well. I think the main issue I had was conflicts with my PCI USB 2 hub card and the Soundblaster Live!
How do you manage file transfer? (USB 2 / CFcard / physical media / other) Was it you that uses an FTP server?
Yeh, i bet the mixer really does help. It's messy enough me having an extension cable out the back of USB 1, extension from USB 2, extension from Wave out 3.5mm, extenstion from lineout (for headphone) and wires for keyboard, mouse and precision pro joystick.To be fair, sound was pretty simple to setup. One you know what resources you want to give to each card its a case of just setting it up. Because the cards are PNP Unisound makes it so simple (For DOS) and You just manage resource in Device Manager for Win98. I think the mixer is the key to sound setups like this, as trying to daisy chain Line out to Line In gets really tiresome, and the mixer eliminates that entirely.
I use a USB 2.0 PCI Card for file transfer or sometimes I'll burn a CD-RW.
