Depends on the model they are offering - if it’s the Etherea then the 2.5kw is £828 on Saturn Sales so they are will be charging £800 to install and I assume this will include pipe work and brackets.
^ Very encouraging that you found this so easy. Thanks for the update about how your DIY system install went.
Encouraging - i keep staring at these cheap systems at aircondirect/ebay wondering if i can be bothered/be able to install them. It does sound as easy as it looks with the exception of course of any complicated and/or long unusual pipe runs.It's a case of hang the bracket, core a hole for the pipes, unbend the pipes carefully and wrap them in tape, feed through the wall, attach them to the condenser and use an allen key to open a valve 5 times to purge the pipes.
It did worry me when I got it all out the box and looked at it for the first time, but after getting a £300 quote and staring at it for a day I decided it wasn't worth it and to just get on with it.
Yeah the indoor unit comes with a 3 pin plug attached. Going out the wall are the gas flow and return, drain pipe and electrical wires to connect to the condenser.Am I correct in saying that power is supplied from inside via a 3 pin plug?
Going to look at getting something installed later this year, not sure mine would be easy to do DIY basically all the drains are going to be tricky. Everything else id be happy to do really.
Unit in the bedroom basically pipes need to go up through the ceiling into the loft along then through the wall and down to the unit.
Unit in livingroom could go through wall then boxed in into the garage, drain could go in with the washing machine then the other pipes up through garage roof to the unit.
Anyone in Manchester recommend anyone? Rather have quality equipment rather than cheap.
Don't bother with something second-rate, buy a proper system from someone like Saturnsales.
How did your install turn out @Firestar_3x ? Did you get the condensate drain issues sorted?
Are you making sure to shut the windows in the day and open them at night.What's the overall running costs with running these indoor Aircons? I've got a new build house, And my god the house hits 30degrees + in the summer, it makes it very uncomfortable to sleep and my kids suffer!
Perks of a highly insulated house.
We leave them open all day, to try get a draft coming through!
That's part of the problem then. Need to draw any curtains on South facing Windows as well during the day.We leave them open all day, to try get a draft coming through!
