What features do you use you watch for? If you're only losing 8% battery life in 24hrs then you're not using all features or disabled a few?
I get solid 3 days out of mine.
Agreed. I have almost all features turned on and I'm getting about 3 days use before needing a charge.
Just try it, turn it on and see how much it goes down in that mode, for me it isn't that much different than the dual display but obviously looks better.
What mode? Always on? I've used that since the start. I wouldn't buy a watch that didn't have it... I understand your point being it doesn't make much difference. I guess we're just trying to give some balance to the actual battery life comment.
Looks like android phone users will be able to use Apple watches soon.
Where did you hear that?
Well, as we've said, most will get 3 days from this. Dual Display pushes it past 7 days I think.
I think we are discussing a different mode, there are three
Yep, that's what I'm talking about. It's dual display because there are literally two screens. The middle image is literally a different screen (LCD I think) which takes much less battery. The other two are from the LED screen.
first thing this morning I was on 81% from 4pm Saturday which was my last charge, just come to put it on and it needs charging.
Why does it need charging if it's at 81%? Or are you saying all of a sudden it's showing 15% or something? If so, that's more in line with the rest of us I guess. Maybe it's just taking time to calibrate the battery?
The battery life sounds right, the battery reading clearly isn't reporting correctly. Maybe reset the watch?
https://9to5google.com/2021/06/10/n...ed-the-wear-os-3-0-update-for-ticwatch-pro-3/Good news from Mobvoi. Ticwatch Pro 3 will be getting the new wear os update later on this year. Yay
Same.
