 - 9 May 2021
 - Uk
How do you know your points?be registered for 180 days and have 1000 posts
Your post count is displayed under your avatar on desktop and to the right of it on mobile.How do you know your points?
1000 posts, that's mentalYour post count is displayed under your avatar on desktop and to the right of it on mobile.
It’s the way it’s always been. The MM is not about codes, it’s a area of the forum that community members can buy and sell to each other safely. The high requirement deters potential scammers and keeps it safer.1000 posts, that's mental
I don't know who decided for that 1000 posts... I can bet the bots can post 1000 in a minute if programmed well...
I get that, the codes need to be moved somewhere else and leave the MM as just buy/sell classifiedsIt’s the way it’s always been. The MM is not about codes, it’s a area of the forum that community members can buy and sell to each other safely. The high requirement deters potential scammers and keeps it safer.
Fingers crossed it happens soon, been on here for 11 years, granted not posted much but it is annoyingThat's the plan.
Does seem annoying that lurkers are forced into typing, but alas, it is what it is.
https://forums.overclockers.co.uk/posts/34864509We may have found a way to move Voucher codes out of the very restrictive MM to a deal GPU section for members who have 50+ post, you will know if you have access as you just need to look up and will see a GPU deals section, if you don't see it, you do not have access!
It pains me to say it but the post count is the right way to go with minimal cost to implement. Imagine doing it by historic purchase history, bet that wouldnt be easy. I like the idea of the "community" being rewarded almost for all the questions and answers
Thanks for the shout, 50~ seems like a nicer number.
On my way to 50 x)
11 years on forums but only 11 posts, thanks for nothing OCUK.
