Tried Superhot in 120hz last night. Didn't notice any difference at all over 90hz.
Have you enabled 120hz in the Quest 2's experimental options section?
I played half life for the first time over airlink today. It played better than when I plugged it in via USB, apart from loading time, I was very surprised! My router was in the room I was playing.
I can finally hide behind stuff etc as I have no real room where the PC is!
Airlink works far better in my experience, especially for Oculus store games.I've not tried airlink yet, I'm quite happy with VD
Virtual Desktop now supports Asynchonous Spacewarp, which is the best frame-rate interpolation technique currently available. I don't think AirLink does.
Vd offers ssw i believe not asw. It's not the same thing. Vd uses the headset to add the extra frames since its not doing much during normal pcvr gaming. It means your computer can focus on as many frames as possible and the headset fills the rest. Very smart solution.
Airlink is pretty damn good, had a smoother experience than with VD.
So in my experience it was choppy/flickering when I played Beatsaber/VRChat, I had to stick with VirtualDesktop.
Not sure if its cause AirLink is more demanding? I don't really get it.
