Ban this userMake the threshold 250 posts... No reason why...![]()
Show that it may not be the best solution. If they card can't even sell.They're still there now, or at least one of them is. Sitting there, taunting me.
**waves**Some members don't have 1000 posts in 10 years. lol
People used the voucher in their baskets but didn't check outWell it worked because all the vouchers are gone. Maybe the rest are for another voucher run you'll have to ask Gibbo why they're still there.
Once you add it to the basket it counts as 'used' - so there are GPUs left but no vouchers
I doubt any voucher system works like that. Any system that does do that is quite stupid as the voucher only should count as used when you've made a purchase.
I don’t make the rules![]()
Is it ok for people with under 50 posts to just post another 25ish in different sections to be able to access GPU deals or is that against the rules? This is only my 24th postNope due to abuse, we are looking at other ways.
Is it ok for people with under 50 posts to just post another 25ish in different sections to be able to access GPU deals or is that against the rules? This is only my 24th post![]()
OK I'll try and look around later tonight or tomorrow. I know I won't be able to participate in today's voucher but hopefully some future onesIf your contributing and posting helpful information and truly getting involved then that is fine, but if you just go around the forum essentially spamming that is no find and you will find your post count reset.
Contribute, this forum is truly huge, anyone can easily post good solid content several times a day without even trying.![]()
I've noticed that there is a limit to how many posts you can do daily. I like that it's set in place but when does that limit get lifted as I had to wait 24 hours to reply to someone who was helping me.If your contributing and posting helpful information and truly getting involved then that is fine, but if you just go around the forum essentially spamming that is no find and you will find your post count reset.
Ok that's great. Thanks for getting back so quickI've no idea its probably a limit set by moderators to stop new members signing up and just spamming, I am sure a moderator can enlighten you but I suspect as your post count gradually increases the limit will probably no longer exist.
Hey Gibbo I notice there's a £10,000 Asus TuF....is that another voucher![]()
