Hi,
Out of interest, and perhaps to get some people thinking about static electricity....Including me.
I suspect many folks do not use anti static precautions. I never used to. Not really. Then half heartedly sometimes. Then I learned a bit about static.
Electronics was my hobby back in the day when integrated circuits such as Cmos and Fets' were a novelty. I'd read in the electronics hobby magazines that static electricity was something we should take care to eliminate or reduce wherever possible.
Before I any knew any better, I was one of those people that boasted "I've never damaged an electronic component or circuit board as a result of static electricity"
How naïve I now realise that was.
Many moons ago I watched an instructional video by some large manufacture (I forget which one). It was intended to educate employees about the causes of failure regards static when manufacturing electronic devices.
A couple of pointers I took from that video were: Static can whack a huge voltage in to a component. Sometimes destroying it completely and instantly, sometimes damaging it so it still works at first but unbeknown to anyone, that static whack could have weakened the P-N junctions in transistors.
Over time, that weakened P-N junction fails due to heat (or whatever) when in use and the component can then fail catastrophically.
"Over time" could be anyone's guess.
Point being, we, the hobbyist PC builders may fail to observe static precautions. Component/circuit board fails or becomes intermittent months or years later.
Time passes.
The cognitive link between failing to take precautions and the delay in the component failing is not made. We then blame manufacturer for not making a long term reliable product, when in fact it may have been our own doing.
I'm tempted to say I think things may have improved regards static affecting circuit boards these days. I really don't know though.
I've waffled a bit here but I'm sure some of you can explain this better than i've tried to.
Or perhaps you see things differently?
What are your thoughts?
Time passes.
