I don't know the laptop, but generally laptops have much harder time keeping things cool and causing cpu/gpu to throttle back even on stock settings.
I wouldn't bother, the chip will turbo to a high frequency for as long as it can stay cool anyway. Overclocking will probably get you worse performajce as it will thermal throttle.
Theres a reason why overclocking is typically done with bigass air coolers and water coolers![]()
I had never thought about overclocking a laptop, if anything i assume you would want to push more juice into the gpu.
I guess you could try and install afterburner overclocking software and see if it gets you any more juice out of your machine. Got to admit laptops do give more headroom for thermals than i expected, i don't know how this holds out in long terms.
Hi, new laptop, Lenovo Legion wih the 5800H. First time with this chip manufdacturer and a gaming laptop. I cannot work out how to begin overclocking. Nothing in BIOS and Ryzen software has nothing. Is this cpu even able to overclock?
Thanks
