*** Microsoft Windows 11 Thoughts & Discussion Thread ***
Ace
Ace
18 Oct 2002
Thanks for the video link, looks like I'll try this out when the RTM or whatever they call the final version these days gets released.
Permabanned
2 Sep 2017
Huge, full screen app draw? its neither of those things, what res you running it at?
As expected, Windows 11 includes an updated task scheduler which is designed for big.little CPU architecture
there are significant performance improvement over Windows 10 for big.little CPUs
https://hothardware.com/news/windows-11-gives-hybrid-architectures-a-single-threaded-boost
The tiling options pop-up when you hover the maximise button is a lovely touch.
So, to summarize.
Microsoft is releasing Windows 11 that looks like a heavily optimised OS for mobile, low performance processors, with in the best case up to 10% performance improvement in those very specific SKUs, theme that looks terrible with this centre-focused position of the taskbar icons, focus on smartphone-type apps, and new improvement to load the necessary drivers on the go...
Meh!
What do the content creators, classic desktop users, gamers get from this?
Nothing!
Permabanned
2 Sep 2017
So, this is just a renamed Windows 10X.
Microsoft should move this "Windows 11" to ultrabooks and tablets devices, while letting the normal Windows 10 live several more years.
Until they find a way, and imagination to build a modern, good-looking OS for all the users, not only those that have low performance, mobile ones.
10 Jul 2010
So, to summarize.
Meh!
Nothing!
You can put the Start menu back to the left hand side, at least in this release.Though, knowing Microsoft's fine wisdom, they will probably remove that ability.
I am also feeling a little cheesed off at the new system requirements which means that I have two machines which will either continue to run Windows 10 or just buy new machines for Windows 11. :rolleyes:
Permabanned
12 Jan 2021
there are simple workarounds to bypass the system requirements.
Permabanned
OP
9 Aug 2008
What the **** point is there in that? Then it's just Windows 10! FFS.
Ace
Ace
18 Oct 2002
Personally I just want it to be very lightweight with great performance, it's mainly just a launcher for the other software
My thoughts exactly, if it's just a less bloated win10 that runs better sign me up. Although I will make it look more like win10. :)
