- 24 Sep 2015
I have used a connect to do this previously but was curious how the amp would be effected by having no speakers connected.
I don't think it'll care that there's no speakers connected.
I've got one, it's ok for the price - similar to a SoundLink or something like that.Considering a SONOS Roam - does anyone have one? What are your thoughts?
I really like the form factor and it would fit great under a monitor in a minimalist setup. It's mainly for music use but I watch a bit of Netflix on the system and do a little bit of casual gaming, any idea if I can run it wired to do away with any delay? Bluetooth speaker delay kills gaming for me.
Certainly hasn't blown me away, but for it's size it's decent enough.
For your use case (if it's going to be wired all the time). I'd say there are better speakers out there. Roams value comes in it being portable, waterproof etc.
How are people finding the software
Honestly I find the SONOS app utterly useless to be honest. I just end up Airplaying to mine now so I can avoid it.
Anything Android based people use as I think Airplay is Apple only?
What are you playing from? If Spotify, you can connect directly via the Spotify app.It's always been a bit rubbish, it's just that now it's totally so!
Cheers.
There's better bass with the Arc and the Beam but to my ears they're both very lacking in bass. You may feel there's sufficient bass but we really didn't.
I don't need big bass tbh, I live in a semi so keeping neighbours happy is important. The Beam and 2 x play:1s do provide ample bass currently.
I have this with one of my Play 5's. It keeps changing its name to Default Speaker. Which is rather annoying.My Play:5 which used to be in my last kitchen and now in my office keeps renaming itself from office to kitchen. I think it wants to move back.
