Hang on a min.
I don't think things are as bad as they seem. Here you can see a hard and soft floor:
There are new minimum hardware requirements for Windows 11. In order to run Windows 11, devices must meet the following specifications. Devices that do not meet the hard floor cannot be upgraded to Windows 11, and devices that meet the soft floor will receive a notification that upgrade is not advised.
Hard Floor:
Soft Floor:
- CPU: Core >= 2 and Speed >= 1 GHz
- System Memory: TotalPhysicalRam >= 4 GB
- Storage: 64 GB
- Security: TPM Version >= 1.2 and SecureBootCapable = True
- Smode: Smode is false, or Smode is true and C_ossku in (0x65, 0x64, 0x63, 0x6D, 0x6F, 0x73, 0x74, 0x71)
So as long as you meet the Hard Floor windows 11 will be installable.
- Security: TPMVersion >= 2.0
- CPU Generation
Well I have all that apart from possibly smode whatever that is. It still says no to W11 though. I think the health checker is having a laugh. My TPM settings in Windows shows a funny make rather than AMD so maybe it's to do with that. If your system is not too old there will probably be a BIOS update.
