- 9 Aug 2008
i watched that at the cinema wowsers along time ago.
I could only get it on VHS. Might watch it this afternoon. Grreat movie.
now thats a blast from the past.
may well do the same later on after work.![]()
Do you hear, Sorceress? The final moment has come. All the forces of Greyskull, all the powers in the universe will be vested in me! ME! And you will cease to exist!
I really hope windows 11 can be used without a Microsoft account. I do not like the sound of this.
Windows 11 LTSC - disconnect the network cable hopefully.
- Windows 11 Home edition requires an Internet connection and a Microsoft Account to complete device setup on first use.
You might not be but Microsoft are. Nobody is forcing you to upgrade. Windows 10 will be supported for a while.
I tried the Health check and it did not run, says update's are managed by an organization?
If you have an old program that doesn't have a security certificate, tough luck.
Same here, took my then 5 year old son to see it on release, his first cinema outing, we both loved it.i watched that at the cinema wowsers along time ago.
- are you using 2060 super as per your sig?If you've signed into Office 365 or other MS apps with a work account, that comes up. You need to remove that account from the Settings app, then try again.
My PC is UEFI, I've enabled fTPM for my Ryzen 3600, but whenever I enable Secure Boot, I just boot to a blank screen after I see the mobo logo![]()
I had to:If you've signed into Office 365 or other MS apps with a work account, that comes up. You need to remove that account from the Settings app, then try again.
