- 18 May 2010
- London
Guess I wont be installing W11, no TPM and no TPM header on my Asus Rog Strixx B550-F.
AMD have software level TPM in the bios which you can turn on.
It will probably update to the final no problem, easy enough to d/l the final iso when its out and update it that way anyway.
Its not unstable by the way, well, not for me anyway, it's been completely solid.
. I can't say where I got it.Trusted platform modules going for silly money on ebay now over £100 i should have bought a load of them while they were cheap!
Just wait for Windows insider build next week.
From what I've found, a known competitor has them on pre-order.
May not even have to update a bios as a lot have it built in.
Example: My asus strix z390-f showed on the compatibility app as not having TPM enabled. So i checked TPM.msc to see what it said and it said it was disabled under firmware/bios.
So off I popped to my user manual and found the TPM setting under pch-fw config, changed the setting from discreet to firmware TPM, restarted and boom - w11 is now compatible.
Have seen similar with Gigabyte etc so worth checking your manual and bios - however I wouldnt leave it on till you want to upgrade to w11.
a lot of mobos will have it, its just the checker wont see it even as an option if at a bios level its disabled or set to discrete. As I said, check your manual and see whats it called. Some are called "trusted computing" as an example.
Worth a check before discounting your current hardware or waiting on a bios flash
Yep same place I bought mine
Now I know I can do it both ways, anyone have a preference, software TPM or using an official chip?
The advantage of a dTPM is that the keys should persist after a BIOS update or CMOS clear. With the fTPM the keys would be lost and you have to reinitialise the fTPM. Personally I’ll get a dTPM just for convenience.
That's only if you actually use it though right? If I never use Bitlocker etc then losing the keys every time I flash the BIOS doesn't matter I hope?
Can you report that bug on github, or post a screenshot and I'll do it for you.New update 2.2.0
Releases · rcmaehl/WhyNotWin11 · GitHub
Pity I now fail due to no WDDM 2 but am on WDDM 3.0 (DXDiag) 3090 FE.
