- 18 May 2010
- London
Guess I wont be installing W11, no TPM and no TPM header on my Asus Rog Strixx B550-F.
AMD have software level TPM in the bios which you can turn on.
It will probably update to the final no problem, easy enough to d/l the final iso when its out and update it that way anyway.
Its not unstable by the way, well, not for me anyway, it's been completely solid.
Trusted platform modules going for silly money on ebay now over £100 i should have bought a load of them while they were cheap!
Just wait for Windows insider build next week.
From what I've found, a known competitor has them on pre-order.
May not even have to update a bios as a lot have it built in.
Example: My asus strix z390-f showed on the compatibility app as not having TPM enabled. So i checked TPM.msc to see what it said and it said it was disabled under firmware/bios.
So off I popped to my user manual and found the TPM setting under pch-fw config, changed the setting from discreet to firmware TPM, restarted and boom - w11 is now compatible.
Have seen similar with Gigabyte etc so worth checking your manual and bios - however I wouldnt leave it on till you want to upgrade to w11.
a lot of mobos will have it, its just the checker wont see it even as an option if at a bios level its disabled or set to discrete. As I said, check your manual and see whats it called. Some are called "trusted computing" as an example.
Worth a check before discounting your current hardware or waiting on a bios flash
Yep same place I bought mine
Now I know I can do it both ways, anyone have a preference, software TPM or using an official chip?
The advantage of a dTPM is that the keys should persist after a BIOS update or CMOS clear. With the fTPM the keys would be lost and you have to reinitialise the fTPM. Personally I’ll get a dTPM just for convenience.
That's only if you actually use it though right? If I never use Bitlocker etc then losing the keys every time I flash the BIOS doesn't matter I hope?
Can you report that bug on github, or post a screenshot and I'll do it for you.New update 2.2.0
Releases · rcmaehl/WhyNotWin11 · GitHub
Pity I now fail due to no WDDM 2 but am on WDDM 3.0 (DXDiag) 3090 FE.
