Setting up Pi-hole
18 Aug 2007
Liverpool
Can AdguardHome provide DNS for multiple VLANs? I have Home Assistant installed on a R Pi4 and running AdGuard Home. But it only seems to handle DNS for the main VLAN.
Yes, though I did read old reports that it only displays stats for the main LAN. AGH development moves quite quickly, so it's probably fixed by now. Try it and see?
25 Mar 2020
OISD.nl and my own custom list in ABP format (works in AdGuard Home but I don't think PiHole is capable of using them).
Great stuff, I've added these on my AdGuard Home (docker install on pi).
Been using AdGuard Home instead of PiHole for a couple of months now, nothing against PiHole its just that AdGuard Home seemed like a more complete package out of the box so thought of trying it out.
Overall its been great and I don't feel like going back to PiHole though some people really like PiHole's UI, I'm fine with both tbh.
As far as block rates go, PiHole with various adlists used to block around 45% of my traffic but a lot of times there were false positives and I'd have to routinely whitelist domains. With AdGuard Home and just the OISD list, its around 32% and I've never had to whitelist any domain so far (of course block rate is entirely usage dependent).
18 Aug 2007
Liverpool
I'm glad it's working for you. My list is very short but it catches a huge percentage of undesirables, because ABP format is expandable (i.e. catches all subdomains and derivatives, including wildcards). If you ever have an issues just message me or open an Issue on the Git.
25 Mar 2020
Awesome. I especially noticed "telemetry.roblox" on your list and there's too much roblox use on my network. Instantly went ahead :).
maj
maj
19 Jul 2010
Durham
Been trying Adguard home free version as an alternative to pihole. Is there a need for their own app if you're using it as DNS server?
From what I can see they support ads in browsers but in-app adverts is only a feature on the premium version. That correct? Using oisd block list and getting ads in game apps for example and when I check query log I can't see the advert being listed to block. Temporarily switched device to pihole and the advert was blocked (using oisd).
That said with pihole I only seem to get ip addresses for devices with pihole set as DNS and DHCP server. Adguard gives each device a name automatically with same settings which makes each device easy to identify to check specific client logs. I would say Adguard has a nicer GUI too.
18 Aug 2007
Liverpool
There's far too little information in your post to effectively help. Blocking ads in-app on which platform? Also, you're talking about 'Adguard home free version', but AdGuard Home only has one version - which is FOSS. Are you confusing the iOS/Android/browser based Adguard apps, which do indeed have a free (browser only) and paid (system-wide) tier? Using the OISD list should yield the same results on either PiHole or AGH, and if anything be better on the latter as that supports ABP format whereas PiHole only supports domain blocking.
How are you using AGH and PiHole? In Docker? Bare metal? Is AGH set up as DHCP server when you're using it? Is it the only DHCP server on the network? Are you setting AGH as the default DNS (and/or DHCP) on a per-device basis and verifying that the traffic is actually hitting AGH from the device in question?
maj
maj
19 Jul 2010
Durham
Thanks for the reply. The ads were on Android and I only have Android mobile devices on my network. I am possibly getting confused about their products. I did read something that suggested there was a premium version which was the only way to block in app ads but can't find it but it may have been referring to their own app rather than AGH.
Both PiHole and AGH are both hosted on a Linux VM until I can learn more about Docker as I'm still learning Linux. Both are configured to be both DHCP and DNS when in use (otherwise everything gets logged as being my router) and router is pointing to AGH as its DNS. DHCP is disabled on router. The only time Pinhole is used at the moment is if I manually point a device to it for testing purposes. Ads are getting blocked by Adguard in general and on that particular mobile device with the in-app ad I just couldn't see where the ad was coming from in the logs. Pihole blocked it straight away with same block list and I'm unsure why.
Man of Honour
20 Sep 2006
You might have DNS bleed somewhere.
maj
maj
19 Jul 2010
Durham
@ChrisD. Thanks may well have been as have since put the phone back onto AGH without any changes and it's now blocking ads in the game. Not sure what's changed but if she's happy I'm happy.
20 Oct 2002
North West
So I reset (not rebooted) my Asus router but when I set my routers dns to my synology, still no dice. So assuming it’s an issue on the nas. Will have to fiddle more.
20 Oct 2002
North West
So...especially for Rainmaker - I re-installed adguard via docker creating a macvlan - giving it a separate IP (which worked fine) - but still no dice. As soon as I add the IP to my asus router, my internet connection dies. Really weird.
20 Oct 2002
North West
So, I seem to have resolved it. Instead of changing the DNS settings under the "WAN" tab, I spotted something on another forum advising to change the DNS setting under the LAN tab, then "DHCP Server" and under "DNS and WINS Server Setting"
So yeah, in adguard rather than getting one entry for my router, i'm getting quite a few - assuming the router just advertises the DNS address.
18 Aug 2007
Liverpool
To test encrypted DNS is working you can do packet capture on the affected port/destination. A quick search will give you the details for your particular OS. If not, you could always test by using dnsleaktest.com - if the DNS provider is showing as Google (in this case) and the DoH is the only enabled DNS, then you're (99.9% likely) sorted. Think twice about using Google for anything with the word 'privacy' in it, though...
I also can’t use cloud flares DoH as it kills nowtv/btsport quality.
As upstream for AdGuard Home or PiHole? You could always use Quad9 and enable EDNS client subnet. That will pass a part of your IP to the streaming service, so they can give you a more local CDN - and hence better quality streams. Read up on the (mild) privacy side effects, to ensure you're completely happy however.
Quad9's EDNS enabled server:
Code:
IPv4
9.9.9.11
149.112.112.11
IPv6
2620:fe::11
2620:fe::fe:11
HTTPS
https://dns11.quad9.net/dns-query
TLS
tls://dns11.quad9.net
20 Oct 2002
North West
Code:
IPv4
9.9.9.11
149.112.112.11
IPv6
2620:fe::11
2620:fe::fe:11
HTTPS
TLS
Im using Google’s DoH solution via AdGuard. Just wanted a way to confirm it was working.
18 Aug 2007
Liverpool
See my edit above, sorry.
Thinking on, @Robert if it's the AGH then you can just go to the query logs page and it should tell you in the info pop ups (click the eye icon on the left of the queries) whether YOUR query was encrypted. Then go to the DNS page and test that the upstream is working.
