Showing at £10.99 here, isn't that the standard price? We're talking Oculus store?
Ah, I'm on Rift S, so I don't see that.
Can I check the quest store when I don't have a quest?
OK, I've answered that question via Google - in theory I can. But I don't quite understand the process of how - if I buy Walkabout through the web-based Quest store - I get it to appear in my Oculus account. Any help appreciated! I don't want to buy and then find out it will only port across if I have the Quest software installed too.
Quest Store: VR Games, Apps and More | Oculus
IF you don't have a Quest/Quest 2, you can't play the Quest version.
But I'm not trying to play the Quest version - I'm trying to buy the quest version, automatically get the Oculus version too, and play the latter.![]()
As per the 48 hour refund deal, I might just give it a go this evening. All for the sake of £3! But it would prove a useful premise.
This does work. I've done it several times. As long as the description says it supports Rift as well as Quest you'll automatically get the both versions.
Its coming to steam next week anyway
