If anything I'd have expected it to be the opposite - now they're becoming electronic they're probably less useful as an 'emergency brake'.Because it’s electronic and your press a button rather than yanking it with your hand.
No, it's emergency brake, the term has been around for ages in the US.I figured e-brake was electronic brake?
Probably as you can still use it if your brakes fail (if still using a cable).
I figured e-brake was electronic brake. Is that not the case?
Yes, the computer will control the clamping force of the brakes. Try it at slow speed. It shouldn't just lock them if working OKSo i drive on motorway 70mph amd my brakes fail so i just yank up the e-brake and all be dandy right?
See Tokyo Drift for appropriate usage.
Rip that e-brake!
wot in my mk3 fiesta?
well they couldn't even spell "all correct" correctlyfriend i got in the usa says its because accelerator is too hard a word to spell and gas is easier. lol
